Problem on Mask
TNGOG
Problem on Mask
Message par TNGOG »
When i use Photomasque, and choose one of the masks, the " slide " masks , the edges are not smooth, like they use to be, and the file size is larger then the rest of the masks, file size for the slide mask is 203 - 250.
Can someone please fix the slide mask edges.
Re: Problem on Mask
Hi too TNGOG, and thanks for your message,
I think you should read the help file of the PhotoMasque module : :)
press the F1 key or menu ? / Information or the eponimous html file in the PhotoFiltre folder.
You can do your proper mask and blur the parts you wish. A mask can be applied in a selected area,
or inversly you can adjust the file to the mask size.
Have a nice day.
