Highlight Question
b1rd
Version de PhotoFiltre : 6.2.3/ PF Studio
Système d'exploitation : Windows XP Home
Processeur : Intel
Mémoire RAM : 3Gigs
Highlight Question
Message par b1rd »
Is there a highlighter or another way to highlight something? (PF v6.3.2)
I've played around...and as usual...it's most likely right in front of me > :oops:
Thanks,
b1rd
Re: Highlight Question
Hi bird,
no specific highlighter tool in PF6, but some other ways to do as it looks like.
First way :
- take an advanced paintbrush tool in a fluorescent color,
- hold shift key, hold left clic and drag mouse on right
- Shift + Ctrl + Z and fade paintbrush tool (to reduce opacity, principaly on a text)
Other way :
- select the area to highlight
- Run Photomasque and chose a mask like "dilution" in color mode with a fluorescent one
- adjust opacity
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Message par b1rd »
Tom, thanks. I think you've helped me before and I really appreciate your assistance.
Any chance a there's a highlighter plug-in coming down the pike? :wink: (OK, I'm lazy.....)
<Kidding>
b1rd
b1rd a écrit :.../... Any chance a there's a highlighter plug-in coming down the pike? :wink: .../...
I didn't know this saying :lol: . Perhaps wish you such a plugin falls under your left mouse click ? :wink:
I think it's not a high priority for the moment,
mostly because the advanced brush tool in the Studio release can directly control opacity,
without using a fade operation.
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Message par b1rd »
Actually, I was able to do what I wanted within three steps after all by back filling and then fading the fill.
Thanks again for the help.
b1rd
