Hi,
Does PhotoFiltre Studio 9.2.2 support, Panasonic's Lumix FZ28 RAW (.RW2) format?
Thanks!
PFS and Panasonic FZ28 RAW
ckit
- Version de PhotoFiltre : 11.7.0
- Système d'exploitation : Win11 Pro x64 25H2
- Processeur : AMD Ryzen 3 3300X
- Mémoire RAM : G.Skill FlareX 3200Mhz 16Gb DDR4
Re: PFS and Panasonic FZ28 RAW
Just try to test
ckit
LOL, I'm getting the camera as Christmas present so I'll have to wait
ckit
Nope, PFS 9.2.2 can't load RW2 images taken with the Panasonic FZ-28 camera!
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
ckit a écrit :Nope, PFS 9.2.2 can't load RW2 images taken with the Panasonic FZ-28 camera!
Best Regards:
ckit
Antonio,
Any chance of updating the RAW support?
I can send you a sample RW2 image if you like.
I will see if a new version of the delphi lib is available. I'm not the developper of this library and can not uppted when i want
ckit
Thank you!
