New Plugin needs testing : Text2Path
cleon
Version de PhotoFiltre : Win XP Pro sp2
Message par cleon »
Hello all, i've just created my first plugin and it needs some testing and constructive coments on how i can improve it... the plugin is called Text2Path and can be downloaded from the plugins page.
Thanks
Cleon. :D
[FrançoisL]I edited the title to be clearer[/FrançoisL]
cleon
Message par cleon »
oh... its not available to the public for download yet... i guess it has to be "approved" first?
Dernière modification par Antonio le 03 mars 2005 9:27, modifié 1 fois.
Benjamin
Version de PhotoFiltre : 6.0
Mémoire RAM : 512Mo DDR 333
Message par Benjamin »
I've activated the plugins because it seems good...
I'm sorry but I don't understand how this plugin works :oops:
cleon
Message par cleon »
I've made a slight modification to the plugin (v0.2 Alpha) and encluded a text file with simple usage instructions.
Fixed a bug where an empty line in the text would cause an error
Fixed a bug in the text rendering
Don't use 'C:\Program Files\PhotoFiltre\Selections\' in your code source but GetExePath + 'Selections'
cleon
Message par cleon »
Thanks Antonio.
I have updated the plugin again with the fix and also added a new feature:
Smooth - which smooths the path before rending the text
Antonio a écrit :Don't use 'C:\Program Files\PhotoFiltre\Selections\' in your code source but GetExePath + 'Selections'
That must be the reason why I didn't undersand, my PF is not in Program Files :D
This plugin is very interesting :)
Would it be possible to add a preview ?
cleon
Message par cleon »
yup :D
cleon
Message par cleon »
FrançoisL a écrit :This plugin is very interesting :)
There is a small thumbnail preview on the plug-in form and one also on the image... check the location settings, the image preview may be hidden by the plugin form being in front of it. Is that what you mean?
cleon
Message par cleon »
plug-in updated again... :)
few bugs fixed
text renders around curves better
interface changed
and some other changes... for the better i hope ;)
cleon a écrit :There is a small thumbnail preview on the plug-in form and one also on the image... check the location settings, the image preview may be hidden by the plugin form being in front of it. Is that what you mean?
I don't find the small preview very practical and would prefer an image preview :oops: because the automatic preview makes the computer freeze every 3 seconds...
pf
Message par pf »
First : Sorry for my English !! :oops: :wink:
This plugin is very nice !!
But, if the path is predefined (round, square, ...... first word misus) or bad file format, an error occured.
:idea: Would it be possible to add a verification function ?
and another to translate "predefined path" to "vector path" for use to this plugin
