re: Window loading error
Allegra
Version de PhotoFiltre : Studio 8
Système d'exploitation : XP Pro
Processeur : Intel
Mémoire RAM : 500
Message par Allegra »
Hi, I'm using PF studio, the previous version before the new 9 version...sorry can't tell you what it is because it's frozen.
I'm working a something and went to use the replace colour and the small pop up window has disappeared, I can't close the program or save the work.
PF is still running but everything is frozen except for the colour picker for the replace colour.
This has happened at odd times, and usually I can get to the pop up filtre window by closing the main workspace window and find it's loaded behind the main workspace window...but not this time.
I'd hate to lose the work, any suggestions would be greatly appreciate.
Re: re: Window loading error
Hi Allegra,
try the actual 9.2.2 on the official web site, or download the latest 8.1.1 from this page :
viewtopic.php?p=31043#p31043
Generaly, it's better to work without switching other Windows applications,
when any PhotoFiltre parameter window is open.
