I am using V6 free version. When I attempt to open a file, the selection window is very small. How may I open the window to full screen size?
Thank you,
eztune
Open File Window Size
- Version de PhotoFiltre : 6
- Système d'exploitation : Vista
- Processeur : Windows
- Mémoire RAM : 2GB
Re: Open File Window Size
Hi eztune,
It's a Windows setting : right clic on the shortcut icon used to open PF :
Open Properties : in the "Execute" box choose the window you wish.
- Mémoire RAM : 2GB
Tom,
Thanks for your response. I must not have asked the question properly.
It is not the PF window I referred to as being too small, but the Open window that is far too small to efficiently locate an image file to work on. The Open window referred to is the Ctrl+O window.
Oh so sorry,
i did red too much fast. Your question was correctly writed.
But i have no issue to your question : the sizes of the open/save windows are defined in the soft program.
Moreover like some other settings which aren't adjustable in Preferences.
However, when you modify it, they are kept during the whole session.
- Mémoire RAM : 2GB
I received an e-mail with the hoped-for answer. The latest version 6.3.2 allows for the Open (file selection) window to be shown as a resizeable window. This allows a much easier ability to locate and select your file. Thanks to all.
