Bit depth
cwilder
Version de PhotoFiltre : don't know
Système d'exploitation : windows vista
Mémoire RAM : enough
Bit depth
Message par cwilder »
how can you change bit depth? Is there a way?
Re: Bit depth
what exactelly do you want to change...don't understand...Image mode (RGB, 8bits, ...)
