Straightening an image?
jhnel
Message par jhnel »
How do I straighten an image in PhotoFiltre i.e. if the horizon in the image is not level?
THanks
Re: Straightening an image?
Hi jhnel,
You can View / Show grid and do Image / Rotate /Free for example. :wink:
What so hard ? :)
jhnel a écrit :it doesn't work - with free, even with a small incriment, the whole image turns much to much - - Picasa has a far superior straightening tool - will wait and see if other members here have a solution - thanks for trying to help
Yes it does work :wink: even with 6.3.1 release,
and if you download the last 6.3.2, you can ajust to 0.01 degree. 8) viewtopic.php?p=144906#p144906
But why not use Picasa if their tools are fast and superior ? :)
