Well. I have a question.
When I put my own image.png into the PngData folder and I try to use it by PhotoPNG...the program tells me the it cannot upload image... Why?
Is the module PhotoPNG can use only the fixed png images?
Thank you.
New module PhotoPNG
Ioly
- Version de PhotoFiltre : 9.2.2
- Système d'exploitation : XP
- Processeur : AMD Sempron(tm) 2800+
- Mémoire RAM : 512 mb
Re: New module PhotoPNG
Use only PNG 32 with alpha channel
