As far as I get it (new user) Photofiltre doesn't wordk with layers. But how can I change an action I performed some time ago when I already performed other actions later on.
For example, I place a text and I want to schange the text color?
How can I change an action later on?
Hi Diego,
That's right, the actual freeware release of PhotoFiltre doesn't work with several layers. However the next PhotoFiltre Studio release will offer (in march) these tools. This next release will not be a freeware one but for a low cost.
With the releases 6, you can chose undo to go back in your actions process. (You may also redo). I suggest you to save regularly the critical steps of your work, so, for example, you can change the text color and later paste again anything you wish.
Evidently is it less convenient than layers, but with a little practise, you will enjoy and appreciate this tool is a very usefull one.
Just note that are two steps when you place your text : So far you don't validate your paste, you can double click on the text and modify the properties.
I hope it's answer your question ?
Pleased to read you.
