creating a 3d cube
diesel
Version de PhotoFiltre : 6
Processeur : 2gh pentium
Mémoire RAM : 512Mb
creating a 3d cube
Message par diesel »
hi,
can anyone help me (via a short tutorial or description) create a 3 sided cube in photofiltre please.
All i need is a 3d cube with the front two sides showing and the lid of the cube but im finding it way too difficult to create in photofiltre.
thanks
diesel
Mémoire RAM : 512Mb
Re: creating a 3d cube
is there any way i can modify the angle of a side of a filled rectangle by clicking and dragging that side of the box?
I am having to use the "image-->rotate" option at the moment but i cannot get the precise angle i require in order to get the edges of the two boxes to meet.
After the paste, use Transform free and change the Skew X and Y values
Hi diesel,
A french tutorial at this adress : http://ressources-photofiltre.com/pages ... _plus.html
It's name : Cube photos ( Pascal Dehont )
or try this direct adress : http://www.ressources-photofiltre.com/T ... photos.htm
To get a raw translation : viewtopic.php?p=127487#p127487
Have a nice day
