Hi. I've got a twain scanner mustek 1200 ub, regularly recognised by photofiltre.Anyway, when I scan a document (not a picture), the image appears blurred. Is there anything I could do?
Thanks
twain scanner
- Version de PhotoFiltre : 6.3.1
- Système d'exploitation : win xp pro
- Processeur : amd 1700+
- Mémoire RAM : 512
Re: twain scanner
Hi lillorizzo,
try to scan at 150 or (better) 300 dpi and verify if your scanner has a clarity refine tool.
If not, you can use Ajust / Contrast or Filter / Sharpen / sharpen edges in PhotoFiltre.
