Color Grabber
b1rd
Version de PhotoFiltre : 6.2.3/ PF Studio
Système d'exploitation : Windows XP Home
Processeur : Intel
Mémoire RAM : 3Gigs
Color Grabber
Message par b1rd »
I've just downloaded a free "color grabber" that allows me to grab any color from a screen shot, then gives me the HTML color code.
Is there a way that I can use this code with PF, rather than taking that same screen shot and using PF's color grabber (Pipette Tool)?
Thanks
b1rd
Re: Color Grabber
Hi bird,
Yes, a simple way : activate the pipette tool, type the web color value in the proper box, and do Enter. :)
So the foreground color will be set to the right value. Don't forget to activate a new tool ...
But PF doesn't work on an external picture. The screenshot must be pasted in the PF workspace, to use the pipette tool.
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Re: Color Grabber
Message par b1rd »
The screen-shot must be pasted in the PF workspace, to use the pipette tool
That's what I was wondering about, thanks. Actually, I never noticed the box for the HTML values before.
b1rd
