Adjusting text
spionfox
Version de PhotoFiltre : 10.3.2
Processeur : AMD64
Mémoire RAM : 1GB
Adjusting text
Message par spionfox »
In the freeware version of Photofiltre I could change the text size by dragging the sides of the containing frame. I cannot do this in Photofiltre Studio. It seems I have to convert to graphic first before I can do any resizing. Is this right or is there a way to manipulate the text first without making it a graphic and then losing some resolution.
Thanks.
Re: Adjusting text
Hi,
more simple : double left clic on the icon of the text layer and change any parameters you wish. :)
To change the size of a text converted to graphic layer, it's better to reduce than to increase.
