Simple question. What exactly does the Image Explorer do? I see it opened a bottom pane, but what do I do from here? I played around a bit, but can't figure it out.
I did do a search within the forum, however the results came up in French, which unfortunately i can't understand.
Thanks in advance.
B1rd
Image Explorer Question
b1rd
- Version de PhotoFiltre : 6.2.3/ PF Studio
- Système d'exploitation : Windows XP Home
- Processeur : Intel
- Mémoire RAM : 3Gigs
Re: Image Explorer Question
click the small arrow button (at middle left) and choose explore a folder for example...
b1rd
Thanks. Saw it before but never bothered to click it.
