How to change the colour of the background
spionfox
- Version de PhotoFiltre : 10.3.2
- Système d'exploitation : WinXP
- Processeur : AMD64
- Mémoire RAM : 1GB
Hi - I have a project on the go with many layers. I want to change the background clour but can't find a way to do this. Is it possible please? Thanks.
Re: How to change the colour of the background
use Edit > Fill and Stroke and check only Fill
spionfox
- Mémoire RAM : 1GB
Thank you Antonio
