Multilingual text?
ellielau
Multilingual text?
Message par ellielau »
I use graphic software for projects in both English and Korean, but I can't seem to get PhotoFiltre to accept my Korean text. I've tried setting it to Korean fonts, but it just sets all of the characters to ?'s.
Any ideas on how to get it to work? =[
Re: Multilingual text?
but when you validate, the text is correct ?
(only in the input box...?)
ellielau
No. After I enter a character, it turns it to a ? and it stays that way even after I attempt to put it on the pictures I'm working with.
PhotoFiltre don't support unicode language :cry:
But you can input the text in wordpad and copy it as image to photofiltre
ellielau
okay, thanks. =]
i'll try that.
