height/width ratio
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
height/width ratio
Message par jimclatfelter »
Is there a way to enter a height/width ratio for a retangular selection. I like that I can click on = (square), 4:3, and 3:2, but those don't cover the range of ratios that I need for various print sizes. Right now I switch to Image Analyzer to make my crop if I need a ratio other than 1:1, 4:2, or 3:2. Is there presently a way do get other ratios. If there isn't, I suggest it for a new feature.
Thanks,
Jim
Re: height/width ratio
Not for the moment :cry:
You can use the manual settings to enter the size with correct ratio and after use the shift key to keep the ratio
jimclatfelter
Hello Antonio,
That's what I was looking for. I didn't know about Manual Settings (Ctrl-G). Now I can do just what I need.
Thanks,
Jim
