Using 6.3.1
I have some photos taken on a hazy/overcast day.
Any way to clean the images up ?
Is there a way to remove the haze ?
sethm1
- Version de PhotoFiltre : 6.3.1
- Système d'exploitation : XP SP3
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Re: Is there a way to remove the haze ?
Hello Sethm1,
If you were to post an example, perhaps someone in the forum could suggest something helpful for your needs. As for actually improving the haze, I do not think it would be possible if the haze is over all the image, however if it is simply a matter of the sky, you may be able to select it and replace it with a sky pattern. I am sure if you put up a sample, someone will be able to anwer your question more specifically. Good luck.
Jack
Jack
sethm1
Yes, the whole photo is hazy - they were very cloudy days and I left my polorizer lens at home.
Hi,
Like Jaume, it's not easy to give an appropriated advice without a bit of view,
cause with PhotoFiltre, there is more a way to skin a cat...
sethm1
how do I attach a photo to a post?
sethm1
sorry - but can you walk me thru this?
I don't have a "host"
If you don't have a web site, you must suscribe a free host to upload your images.
sethm1
and how do i do that?
what host web sites are there? how do i find one?
