Hi,
I am using PhotoFiltre 6.3.1 (1/13/2008) (English version).
When I select: File - Image Properties - EXIF
I get in Exposure Time 10/1000 sec instead of 1/100 sec
as it should be and shows in other programs like IrfanView and XnView.
Also, is there a way to control the amount of Sharpen or Soften,
a number from 1 to 100 that can be entered so it isn't so strong?
Thanks!
PhotoFiltre 6.3.1 shows 10/1000 sec for 1/100 sec in EXIF
dvip
Re: PhotoFiltre 6.3.1 shows 10/1000 sec for 1/100 sec in EXIF
Hi,
most of all effects can be post-faded with menu Edit / Fade or Shift + Ctrl + Z.
dvip
Hi Antonio,
If the EXIF problem is a bug this one shouldn't be too bad to fix.
It may be the format in which the data is presented after it is
read from the EXIF structure. If the program is writen in C++
Builder perhaps a sprintf()/swprintf() format problem.. Although it
looks like Delphi.
By the way, PhotoFiltre is very nice, fast, small and to the point!
Hi Tom,
Isn't that the Undo key? What I am looking for is a way to apply
let say Sharpen at 20% not at 100%. It looks like PhotoFiltre's
amount of Sharpen is too strong by default. Is there any way to
control the amount of Sharpen you apply to a picture?
Thanks
looks like Delphi.
Hi Tom,
Thanks
dvip
Thanks Tom! That did it!
