BRUSHES
bombdiggity_bre
BRUSHES
Message par bombdiggity_bre »
um im new here
and to photo editing
and i have no clue how to use brushed
that probably sound so stupid
but can someone help me
Re: BRUSHES
Hi,
can you specify for which version ? PhotoFiltre 6 freeware, or Studio with layers and advanced paintbrush tool ?
Thanks to post in International Graphical support about this kind of subject. :)
Krisitina__829
Re: BRUSHES
Message par Krisitina__829 »
i have the free version of it
can i still load brushes in to it?
Re: BRUSHES
Hi,
In the free version you have to use brushes as masks with the module PhotoMasque.
Download the brushes in "Masks" folder of "PhotoFiltre" folder
Draw a selection on the background picture, call PhotoMasque and select the brush you have downloaded,
you can use color to tint the brush, and adjust the opacity.
