File Based Nozzle Tool
Retry Man
Processeur : İCORE5
Mémoire RAM : 4GB
Message par Retry Man »
bonsoir,
nozzle tool in PFStudio can use maximum 100 nozzles in one session, +brushes tool can use as many as it can since it first opens the file of +brushes, can the nozzle tool be devoloped like +brushes tool enabling limitless number of nozzles being used in one session :?:
Re: File Based Nozzle Tool
I think i will force the value to 200 in the next version...
Retry Man
Processeur : İCORE5
Mémoire RAM : 4GB
thank you very much for your support... :)
