Blurry picture
Niels
Version de PhotoFiltre : Studio 9.1.0
Système d'exploitation : Vista ultimate
Processeur : E6400 2,13GHz
Mémoire RAM : 2048MB PC6400
Blurry picture
Message par Niels »
Hi people,
Can someone tell me what to do, to make this picture normal again. It is now blurry but i need to see the pixels.
Re: Blurry picture
Hi Niels,
I don't understand the reason of your question. :shock:
If you did a wrong operation, just before, you can undo by clicking on the red arrow, or menu Edit / Undo.
If the blur image becomes from a saved image you can try to Reinforce : menu Filter / Sharpen / Reinforce or the good icon Reinforce
But this good tool can't do miracles in all cases. :(
Always do a duplicate image to work, and save as an other name to keep an integer original image.
Niels
Re: Blurry picture
Message par Niels »
I did nothing, this is what it normally does.
Re: Blurry picture
So, i didn't see you were in zoom at 1600%, i think i have understood now. :wink:
In menu View you have to uncheck Antialias to see the natural pixels
