thats it? photofiltre must go
dorf
Processeur : pentium 1.45ghz
Mémoire RAM : 2gb
Message par dorf »
i installed PhotoFiltre Studio 9.2.1 on my sister pc ,reason was that there is right languake and i tought that it is easy to use beginners. But that was mistake.
There is no logic at all those tools and them are not working properly.
So i choose Photoline 32 instead PhotoFiltre, wrong language is not so bad thing when software works O:K.
keep your crap... :clap:
Re: thats it? photofiltre must go
Everybody can look midday at his door, and the logic of the ones aren't the logic of some others...
Anyway, the thousands users of PFS have made their own viewpoint from longtime ago.
