Hello
Here are my suggestions for PhotoFiltre Studio 9.2.x:
a) File -> New
recognize/set the size of the Picture/ScreenShot from the clipboard.
b) New function: "View -> Show ruler"
Adds a vertical and horizontal ruler around the picture.
c) New function "helplines".
If the ruler is on, you could drag&drop from the ruler a helpline.
d) New settings for "rounded rectangles"
- size/radius for the rounded edges in pixel
e) Add a button "Negative/Inverse" (STRG + I) next to Greyscale, Sepia and old photography
f) Support for web color input. Like #58595B
g) Save a picture with a target filesize. Like 200 KB.
Option: "Don't compress under xx%".
For "Automate / Batch" too.
h) If "rounded rectangles" is active, show it like we click (and hold) on the button.
Please with the other selection forms too.
edit 1:
i) save as .ICO (for example favicon.ico)
--> It is in Version 9.2.1 by Tools -> Export as Icon
edit 2:
j) If we use the selection tool the first time, we can't select outsite the picture.
But if the selection is still active and we size the selection outsite the picture, it works but we can't "touch" the "border" of the selection, to resize it again.
I need this for ellipse selections.
(difficult to discripe it, but I hope you understand me)
k) Add "Tools -> set wallpaper -> Stretch to screen"
l) Add a function to make it possible to create a "smooth selection" (gradient ?) about x Pixels
m) Possibility to center the picture on the "workplace".
It is better for working with layers and selections.
n) The postitions of the "layer thumbail" and "plugin bar" are not changeable (left, right and floating)
I prefer: "Tools palette" = left, "layer thumbnail" = right and "plugin bar" only if needed
... to be continued
Many Suggestions / Requests for PhotoFiltre Studio 9.2.x
MrX1980
- Version de PhotoFiltre : PhotoFiltre Studio 10.1.0
- Système d'exploitation : Many Windows Versions
- Processeur : Most are AMD and some Intel
Re: Many Suggestions / Requests for PhotoFiltre Studio 9.2.x
a) ==> don't need this function, use the function "Past as new image" !
b) ==> not for the moment (lot of works). Use the grid with 1 cm or inch for example...
d) ==> not esay to add this option in the tool bar (no space in the selection area)
e) ==> for me, don't need this
f) ==> allready exists, use the pipette tool to input the color !!!
i) ==> why if the function export as icon exists ?
MrX1980
o) Close dialog: please add "All No" (save nothing and close all Pictures) and "All yes" (save all with a filename or ask for a filename)
p) Please add a "trapeze-selection"
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
The next version possible...I thinkMrX1980 a écrit :...
MrX1980
q) It seems that I only can resize the rectangle with the mouse after the first selection.
By ellipse, rounded rectangle, rhombus and the triangles it doesn't work. There I can only move the selection.
That would be nice if it works with the mouse for all selections formats.
With right click -> manual settings it is time intensive to "reach the final result".
menu selection > show bounds
MrX1980
Thx and merry Christmas and a happy new year !
Mészáros Tamás
Look this: Please use the Measurement plugin.
