This may be both a question and a suggestion. I have noticed that when I right click on an image and select to have the document opened using PhotoFilter, that each subsequent document so opened opens each selected document in a separate window.
As for the question aspect of my post, is there a way to configure PhotoFilter to open all documents within the same application window? If not, my suggestion is to consider that option as a possibility.
Thanks for a great program,
Opv
Opening PhotoFilter Application
- Membre d'honneur
