¿command line in PhotoFiltre?
deckard
Version de PhotoFiltre : PhotoFiltre 6.3.1
Processeur : pentium 4
Mémoire RAM : 256 MB
Message par deckard »
I am newbie in photofiltre . I would like to know command line for :
import clipboard
capture screen
For example , in xnview is:
/clipaste
/capture
Thank you
Re: ¿command line in PhotoFiltre?
Hi deckard,
sorry there are no command lines for PhotoFiltre. :(
It wasn't built to enable this function and the whole code would be remake to.
deckard
thanks , Tom :clap:
