@ndreas
Messages : 3 Inscription : 02 mai 2008 13:10
Message
par @ndreas » 02 mai 2008 13:13
Hello,
I want to make an easy puzzle for kids.
Please look at my attachment. The result should look like that.
So I have a picture, cut it in pieces, rotate and frame them.
Is this possible with PhotoFiltre?
Messages : 13349 Inscription : 02 févr. 2005 9:35
Message
par Tom » 04 mai 2008 21:18
Hi, andreas,
Yes, it is. Can you explain what is so difficult to do ?
Mészáros Tamás
Messages : 126 Inscription : 13 juin 2006 11:44
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message
par Mészáros Tamás » 05 mai 2008 7:44
@ndreas a écrit : Hello,
Yes. Filters menu...
with PhotoFiltre Studio.
@ndreas
Message
par @ndreas » 07 mai 2008 15:03
But I don't know how!
Can you explain it step by step?
Message
par Tom » 07 mai 2008 18:55
You don't need a tutorial to draw a selection and cut it.
Then you can paste the piece on the final image and do right clic in the pseudo selection,
Transformation/Transform free and you can rotate and displace by offset the piece to paste.
