Impossible GRADIENT TEXT ......??????
worried
Version de PhotoFiltre : 9.2.0
Système d'exploitation : Windows XP pro
Processeur : AMS Sempron(tm) 2600+
Message par worried »
Hello.
I try use filtre in Text. But any option in Menu -> Filtre is unactive.
Here is steps:
- Open image.
- Open layer (canvas size - black)
- Copy image and paste into layer
- Merge two layers in one
- Open text (color Gray)
- Then i want Menu -> Filtre to select gradient - but no one filtre is active!!! :x
This is intolerable!!! :shock:
The half program is not work! :!:
Or..... the program working only on half!
Here i read how to use GRADIENT TEXT:
http://frontpagesolutions.com/photofilt ... /index.htm
Is it BUG? :cry:
What is exact steps to create Gradient Text???? :roll:
..... and why is this "Transform to selection". I use this and "Filtre" stil unactive! This option i see USELESSLY
Thank you in advance.
roner
Système d'exploitation : xp sp2
Processeur : centrino duo
Mémoire RAM : 2 gb
Re: Impossible GRADIENT TEXT ......??????
Message par roner »
Right click the text layer you want to use filters on ; -convert text to image layer.
Now you can add all the filters you want. Downside; you cant change the text after you made it an image layer.
Hope this helps you out...
Hi,
Yes, right answer, any filter can only work on an image layer, and not on a tool layer. This isn't so intolerable ? :)
"Transform to selection" does not be applied on a tool layer, too.
On an other layer, it creates a selection ,(and not a text layer) based on the main choices of the text dialog box.
worried
THANK YOU ALL - VERY MUCH! :mrgreen:
I was create 35 seconds movie film in .MOV for proof, but as i see everything is OK! Im very glad now! THANK YOU AGAIN! :wink: SO THANK! :clap:
