Bug report
roner
Version de PhotoFiltre : 9.2
Système d'exploitation : xp sp2
Processeur : centrino duo
Mémoire RAM : 2 gb
Bug report
Message par roner »
Sorry if this has been reported before.
With overlapping fonts the transparency gets messed up when the antialiasing is on in the text box (on by default).
A bit hard to explain, but this is what happens:
Re: Bug report
Yes, with PF, antialias need to check the bold option with text :wink:
roner
Mémoire RAM : 2 gb
Re: Bug report
Message par roner »
Ok, so there is no way to fix this?
Re: Bug report
not for the moment :cry:
