Rotate Free
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Rotate Free
Message par jimclatfelter »
When I use Transform/Rotate Free, the dialog box remains on the screen after the operation is finished. I have to go to the menu again and call up Rotate Free a second time and then press Cancel to get rid of the dialog box. Does anyone else have this problem? Can it be fixed? (I believe it has happened with some other operations that I use only rarely, but I don't remember which ones. I use Rotate Free whenever I get a scan that isn't straight.)
Thanks,
Jim
Re: Rotate Free
Hi Jim,
very glad to read you again. :)
This well known bug seams to be fixed by the new 9.2.0 beta release, which can be downloaded from this post :
viewtopic.php?p=137444#p137444
To fix the issue, Antonio did resolve the bug by shut off the dialog box before processing the function.
Some other functions are advanced in 9.2.1 beta test, but this future release is not yet a public one.
Antonio said the 9.2.1 will comming out at the end of this month.
Very good week end
