- [Fix] Allow correct avatar caching for CGI installations. (thanks wildbill)
- [Fix] Fix disabling of word censor, now possible again
- [Fix] Correctly quote db password for re-display in installer (Bug #16695 / thanks to m313 for reporting too - #s17235)
- [Fix] Correctly handle empty imageset entries (Bug #16865)
- [Fix] Correctly check empty subjects/messages (Bug #17915)
- [Change] Do not check usernames against word censor list. Disallowed usernames is already checked and word censor belong to posts. (Bug #17745)
- [Change] Sped up viewforum considerably (also goes towards mcp_forum)
- [Fix] Allow editing usernames within database_update on username cleanup (Bug #18415)
- [Fix] Use proper title on index for new/unread posts (Bug #13101) - patch provided by Pyramide
- [Fix] Allow calls to $user->set_cookie() define no cookie time for setting session cookies (Bug #18025)
- [Fix] Stricter checks on smilie packs (Bug #19675)
- [Fix] Possible login problems with IE7 if browser check is activated (Bug #20135)
- [Fix] Fix possible database transaction errors if code returns on error and rollback happened (Bug #17025)
- [Change] Allow numbers in permission names for modifications, as well as uppercase letters for the request_ part (Bug #20125)
- [Fix] Use HTTP_HOST in favor of SERVER_NAME for determining server url for redirection and installation (Bug #19955)
- [Fix] Changing order for post review if more than one post affected (Bug #15249)
- [Fix] Prepend phpbb_root_path to ranks path for displaying ranks (Bug #19075)
- [Fix] Allow forum notifications if topic notifications are disabled but forum notifications enabled (Bug #14765)
- [Fix] Fixing realpath issues for provider returning the passed value instead of disabling it. This fixes issues with confirm boxes for those hosted on Network Solutions for example. (Bug #20435)
- [Fix] Try to sort last active date on memberlist correctly at least on current page (Bug #18665)
- [Fix] Handle generation of form tokens when maximum time is set to -1
- [Fix] Correctly delete unapproved posts without deleting the topic (Bug #15120)
- [Fix] Respect signature permissions in posting (Bug #16029)
- [Fix] Users allowed to resign only from open and freely open groups (Bug #19355)
- [Fix] Assign a last viewed date to converted topics (Bug #16565)
- [Feature] New option to hide the entire list of subforums on listforums
- [Fix] Custom BBCode {EMAIL}-Token usage (Bug #21155)
- [Fix] Do not rely on parameter returned by unlink() for verifying cache directory write permission (Bug #19565)
- [Change] Use correct string for filesize (MiB instead of MB for example)
- [Change] Remove left join for query used to retrieve already assigned users and groups within permission panel (Bug #20235)
- [Fix] Correctly return sole whitespaces if used with BBCodes (Bug #19535)
- [Fix] Quote bbcode parsing adding too much closing tags on special conditions (Bug #20735)
- [Change] Added sanity checks to various ACP settings
- [Change] Removed minimum form times
- [Fix] Custom profile fields with date type should be timezone independend (Bug #15003)
- [Fix] Warnings if poll title/options exceed maximum characters per post (Bug #22865)
- [Fix] Do not allow selecting non-authorized groups within memberlist by adjusting URL (Bug #22805 - patch provided by ToonArmy)
- [Fix] Display "empty password error" within the login box instead of issuing a general error (Bug #22525)
- [Fix] Allow & and | in local part of email addresses (Bug #22995)
- [Fix] Do not error out if php_uname function disabled / Authenticating on SMTP Server (Bug #22235 - patch by HoL)
- [Fix] Correctly obtain to be ignored users within topic/forum notification (Bug #21795 - patch provided by dr.death)
- [Fix] Correctly update board statistics for attaching orphaned files to existing posts (Bug #20185)
- [Fix] Do not detect the board URL as a link twice in posts (Bug #19215)
- [Fix] Set correct error reporting in style.php to avoid blank pages after CSS changes (Bug #23885)
- [Fix] If pruning users based on last activity, do not include users never logged in before (Bug #18105)
- [Sec] Only allow searching by email address in memberlist for users having the a_user permission (reported by evil<3)
- [Sec] Limit private message attachments to be viewable only by the recipient(s)/sender (Report #s23535) - reported by AlleyKat
- [Sec] Check for non-empty config.php within style.php (Report #s24575) - reported by bantu
- [Fix] Find and display colliding usernames correctly when converting from one database to another (Bug #23925)
NB pour les développeurs de phpBB : tout le monde n'utilise pas Linux et diff !
