Glass Effect ??
b1rd
Version de PhotoFiltre : 6.2.3/ PF Studio
Système d'exploitation : Windows XP Home
Processeur : Intel
Mémoire RAM : 3Gigs
Glass Effect ??
Message par b1rd »
My apologies for the same questions in two different areas. I'm not able to delete this, or the one above.
Hello to the forum and thanks to the staff for a great site!
Can somebody tell me if there is an add-on to PhotoFiltre so I can give a Glass effect to an image? I mean the effect where it looks like there's a slight reflection, as if the image was on something shinny.
I'm using v6.2.3.
I tried the search, however I am only able to understand English. I tried to translate the site, but I was told it was not supported.
Thanks
b1rd
PS- Love the program !!!!!
Dernière modification par b1rd le 15 avr. 2008 1:26, modifié 1 fois.
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Re: Glass Effect ??
Message par b1rd »
I think I need to move this into the add-on section.
My apologies.
Re: Glass Effect ??
Hi b1rd,
You have several plugins 8bf with Glass effect, but only with the Studio's version.
Re: Glass Effect ??
Hi bird,
To translate some french messages, you can find a solution in head of the International/Tutorials section :
viewforum.php?f=22
To do a glass effect with the PF6 release :
- Select the area to process with the appropriated selection tool
- apply Noise : menu Filter/ Noise/ Add noise 99 one or twice.
- add some gammas on the whole area to process or in new areas of the first one :
menu Adjust/ Gamma correction : increase to 150.
- on the whole first area apply a gaussian blur : menu Filter/Optical effect/Gaussian blur
You can find also other very good tutorials on the web site of Bill, to do glass effects :
http://frontpagesolutions.com/photofiltre/index.htm
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Re: Glass Effect ??
Message par b1rd »
Thanks-you for the responses. I'll play around with some of the techniques.
I did find the Reflet stand alone in this forum as well. Very cool.
Thanks again,
b1rd
