I created an image, then I skewed the image. Then I cut the image after selecting just the scewed image. Then I pasted as new image. The background still comes with it. I want only the screwed image. Can't seem to get it. Whenever I go to paste it in, the image is scewed with a rectangular background
Thanks
Removing the background! Help!
Kike
- Version de PhotoFiltre : 6.3.1
- Système d'exploitation : xp
- Processeur : 1gig
- Mémoire RAM : 256
Re: Removing the background! Help!
Hi ,
It happends sometimes when you have done a copy/paste in another windows application.
You must save your work and quit and re'open PhotoFiltre.
