Hi, I need a little help with framing. Basically, instead of setting how big I want the frame, I want to frame the whole picture except certain parts.
Here's something that I want:
But I only want to highlight this part:
Please let me know how I could select something, and frame everything around it.
Thanks
help framing
mitchipr
- Version de PhotoFiltre : 6.2.7
- Système d'exploitation : Windows XP SP 2
- Processeur : P4 3.2Ghz
- Mémoire RAM : 1 GB
help framing
Dernière modification par mitchipr le 25 mars 2008 21:40, modifié 1 fois.
Pierre-Andre
- Version de PhotoFiltre : PFS 10.
- Système d'exploitation : Windows XP PRO Pack3
- Processeur : Intel Corel 2Cpu 6300 MSIX 7100 GS
- Mémoire RAM : 3 Go
Re: help framing
Hello,
I am affraid no one caught your question unless you would have plenty answers.
Please make your question clearer.
Framing ... as so many meaning ?
mitchipr
Re: help framing
Hi, framing is one of the options from photofiltre.Pierre-Andre a écrit :Hello,
It's on Filter > Frame > Simple Frame (is the one I use).
What it does is it creates a frame around an image, so it'll look like a picture frame. What I want to do is select only parts of a picture that won't be a frame, and everything else around what I select will be a frame.
The option they have is how big the frame is, meaning how many % of the picture it'll cover with a frame.
Let me know if I need to explain better.
Re: help framing
Hi,
I think you are too worried by a strict frame function.
If you want to get somethink like that :
[img]private[/img]
You only need to invert your selection and increase gamma.
[img]private[/img]
Dernière modification par Tom le 25 mars 2008 23:12, modifié 1 fois.
mitchipr
Re: help framing
Tom, that is exactly what I want!Tom a écrit :Hi,
I think you are too worried by a strict frame function.![]()
You're right about me being strict, but this is so that there won't be any confusion on my side.
Could you elaborate or make it into step by step? I'm really new at this and don't understand things the first time...
Thanks for doing it and I hope you could teach me how.
Re: help framing
Oh it's really very easy :
- draw your selection
- right clic in the selection / Invert selection
- menu Adjust / Gamma correct
To learn more with PhotoFiltre, you can have a look at this page :
http://photofiltre.free.fr/tutorials_en.htm
or the tutorial section of the forum :
viewforum.php?f=22
viewforum.php?f=22
