Offlate, I somehow get bunches of requests by email about the libgfl211.dll files (for use with the XnView import plugin).
For easy access I'll put everything ther is to know about it into this message...
You can download the needed dll files from here :
http://plugins.photofiltre.free.fr/XnViewDll.zip
Unzip them (for example with izarc at http://www.izsoft.dir.bg/ )
and place the file in the same directory as the photofiltre.exe file
(Do not put these files in the "plugin" directory. this does not work)
restart photofiltre and everything should work.
Regards
[Tom] I tag this topic as [Ref] Reference or recommandation for research [/Tom]
libgfl211.dll files
- Membre d'honneur
- Version de PhotoFiltre : 6.1.1 NL / 7.0.1 NL
- Système d'exploitation : Windows XP Pro/SP2
- Processeur : Pentium IV @ 2,66 Ghz
- Mémoire RAM : 704 MB
as the link above does not work (well it does work just the [url] is out of the link)
- Mémoire RAM : 1536 Mo DDR
- Membre d'honneur
