How to install PhotoMosaique and Reflet?
Scrappy Smile
Système d'exploitation : Windows Vista
Processeur : Intel Core Duo Processor T2310 1.46GHz
Mémoire RAM : 4 gb
Message par Scrappy Smile »
Can anybody help me by telling me how I install PhotoMosaique and Reflet??? Very happy for any help I can get!!! :lol:
Jepe
Version de PhotoFiltre : PF 6.4.0 & PFS X 10.3.0 beta
Système d'exploitation : XP SP3
Processeur : AMD Sempron 3100
Mémoire RAM : 1536 Mo
Re: How to install PhotoMosaique and Reflet?
Message par Jepe »
hello,
As every *.zip file you have to uncompress it in a folder of your choice and then start it with the *.exe file. You could also create a shortcut of the *.exe file on your desktop and start it from there.
Best regards
Jean-paul
Hi,
These two softs don't need any install. They are stand alone programms and may be unzipped in the folder of your choice.
Evently on a USB key, like PF6. :)
Scrappy Smile
Mémoire RAM : 4 gb
Thank you so much for your help! :D
