Portrait - Replace half-closed eyes - => PF Studio
You need help to start ? Or to use a plugin ? Use the tutorials ! / Ĉu vi bezonas helpon por starti ? Aŭ por uzi etendadon ? Usu la Didaktikojn !
Hi,
Perhaps, it happens that you take some group photos,
or a solo portrait on a well appreciated background,
and you realize with horror that one or more characters
had shut one's eyes tight.
Fortunately you have been far-sighted, and thought about doubling the catch,
or you have the chance to get a portrait of the same person,
in another context with a different background,
but with a lighting and an attitude quite close to the picture you want to enhance.
Well, I fairly like the background of the photo on the left and I will try to replace the face
of the anchorwoman, for the one of the right photo, which is much more to his advantage.
Image . . . Image
Following this tutorial for PhotoFiltre Studio :
http://jptom.free.fr/Tuto_En.html#YeuxMiClos
here is something you can get :
Keywords for research : closed half-closed half change open eyes
Retry Man
Processeur : İCORE5
Mémoire RAM : 4GB
Re: Portrait - Replace half-closed eyes - => PF Studio
Message par Retry Man »
thank you very much Tom :D , for all your helps, ... i am grateful ...
Hi Retry Man,
Thank you for your comment. It's a pleasure if my explanations are useful.
And when i can see so fine results with your nozzles, i'm very satisfied. :)
