Studio 9.1.0 won't print under 98SE
dirtyoldm
Système d'exploitation : 98SE
Processeur : Athlon X2
Mémoire RAM : 1 GB
Message par dirtyoldm »
PhotoFiltre seems to be a great small photo editor... and exercise for our high school French!
But we just downloaded the 30-day demo and it will not print under 98SE.
The little printer tray icon shows for a second or two, then disappears and nothing happens.
It is a Canon S750, and we tried Spooling, Print While Spooling, No Spooling, etc.
We tried large and small color and B&W images.
Yes, it prints from other programs.
Printing works fine under XP SP2.
Do anyone else have this problem?
If so, what is the last version that prints under 98SE ?
Re: Studio 9.1.0 won't print under 98SE
==> no, now evolution are not for win98 (two old system for fixing :cry:)
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
dirtyoldm a écrit :PhotoFiltre seems to be a great small photo editor... and exercise for our high school French!
HP ? Impossible? :? Another printer?
dirtyoldm
Mémoire RAM : 1 GB
Re: won't print under 98SE - thanks for the quick answer
Thank you Antonio, though that is not the answer we wanted to see!
Quelle dommage, everything else works OK under 98SE.
I guess it's time to change the Download page which says
"Compatibility : Win 98, Win Me, Win NT, Win 2000, Win XP, Vista"
Hi,
it would be a shame if you could'nt take advantage of the last picture enhancements from Studio.
When your work is completed, i think you save it. So, it's possible to print it with another application more compatible with 98 SE,
like a good freeware viewer as XnView, IrfanView or, why not, an older PhotoFiltre 6 freeware release :
viewtopic.php?p=31043#p31043 :)
==> no because lot of printers works nice with photoFiltre. only few printers an scan are not compatible :wink:
dirtyoldm
Mémoire RAM : 1 GB
Good idea, Tom. We have IrfanView.
Thank you, Antonio.
It did not occur to us that a different printer might work.
By the way, our old parallel Artec scanner works fine in98SE.
