error message
karimommy
- Version de PhotoFiltre : 6.3.1
error message
I am recieving the message "Not enough storage space to process this command". ver 6.3.1 Any ideas?
Re: error message
It's a memory error. reboot ytour pc and try again...
karimommy
Re: error message
this was happening yesterday also. i have rebooted and still run it to the problem.
Re: error message
what is the function used ?
what is image size ?
what is your memory available ?
without basic information, we can not help you
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: error message
I think isn't enough free hard disk drive space...or flash drive little?karimommy a écrit :this was happening yesterday also. i have rebooted and still run it to the problem.
Best Regards:
Silversleeves
- Version de PhotoFiltre : Studio X 10.2.0
- Système d'exploitation : Windows XP SP3
- Processeur : Intel vPro Dual 1.8G
- Mémoire RAM : 1 GB
Re: error message
If this is a closed thread or outdated in some way, I apologize.
I seem to be getting this error in PhotoFiltre Studio X 10.1.0. It most often occurs when pasting large pics from the clipboard, usually copied from a Web browser window.
The latest error involved a picture that was 552x811@24 and which the browser estimated had a file length of 553.45 KB.
In IrfanView this latest clipboard copy pasted fine, but this added the extra step of saving the picture as a file, opening it in PhotoFiltre Studio X, editing it, and re-saving, which creates another "generation" and degrades the quality of the picture data etc.
It seems as though PF 6 and PF Studio have trouble pasting in true-colour pics over a half a megabyte in length. Maybe there's some limit or code "hook" that keeps it from accepting all the data passed to the clipboard from another program, as a means to avoid crashing the app itself. Perhaps in a future version of Studio this can be worked around? I hope it's soon.
BZT
BZT
Re: error message
==> it's not a photofiltre message but a windows system message. I can not fix this, it's better to searsh the origin. For me it's when the system try to copy to the clipboard a full image (not only the definition).
I don't know the method used by IrfanView, perhaps IrfanView don't copy/paste using 24 or 32 bits uncompressed but use the native Format of the image. In PhotoFiltre, i force the 24 or 32 bit mode because it's an image editor, not a viewer, and of course need lot of more memory
Adracamas
Re: error message
This is possibly very old but hopefully this will help.
It's not speaking of storage as in hard drive space. It is speaking of your system RAM. If you have your Histories all the way up these historys will consume memory and in turn cause this error to pop up on large images. If you reduce your history pages the error should go away (assuming you have the ram to back up editing the large file)
