I guess there is no Mac version of PhotoFiltre..? I used to have PhotoFiltre on my PC and I really love the it.
PhotoFiltre for Mac?
Silva
I'm not sure if this is even the right place to put this, but...
So, is there any way for me to get it work with Mac? I've come to understand that I should have some kind of emulator, but I have no idea what kind of. :/ Please, tell me what to do! I'm not good at all with computers.
Re: PhotoFiltre for Mac?
No mac version
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Under Debian Linux with Wine...
(Windows emulator) and Ubuntu with wine...run...I'm tested.
Silva
Yeah, I've figured that much... Anyway, if there is somekind of emulator I should use, please give me download link. ^___^ I've got MacBook with OS X 10.4 if that's any help...
I still really suck with this thing. >__>
Mészáros Tamás
I understand your problem, but very interest question. Answer: I DON'T KNOW...
Please search with Google on the net. Win emulator program that's under run
MAC OS X. May be find possible...program.
Best Regards:
Best Regards:
Dernière modification par Mészáros Tamás le 22 janv. 2008 18:14, modifié 1 fois.
Mészáros Tamás
http://www.macwindows.com/emulator.html I find this page...Silva a écrit :Yeah, I've figured that much... Anyway, if there is somekind of emulator I should use, please give me download link. ^___^ I've got MacBook with OS X 10.4 if that's any help...
http://www.lismoresystems.com/en/ this another page.
http://bochs.sourceforge.net/getcurrent.html open source...
Best Regards:
Dernière modification par Mészáros Tamás le 22 janv. 2008 18:12, modifié 2 fois.
Mészáros Tamás
http://www.iemulator.com/ this another program for MAC OSXSilva a écrit :Yeah, I've figured that much... Anyway, if there is somekind of emulator I should use, please give me download link. ^___^ I've got MacBook with OS X 10.4 if that's any help...
Thank you for your interest in iEmulator!
You can instantly download the full iEmulator package, including: The iEmulator 1.7.9 PC Emulator
Comprehensive documentation, including step-by-step instructions on installing Windows 98, 2000 and XP
A DOS operating system, including a DOS boot floppy image and a DOS formatted hard disk image
Email Support
All future iEmulator updates at no charge
for only $23.95. Low cost...but no freeware ... sorry...
Silversleeves
- Version de PhotoFiltre : Studio X 10.2.0
- Système d'exploitation : Windows XP SP3
- Processeur : Intel vPro Dual 1.8G
- Mémoire RAM : 1 GB
MacBook Pro's are Intel Macs and can run Windows XP and Vista with Apple's BootCamp technology. Since the release of OS X 10.5 (aka Leopard), BootCamp has gone "pay-to-play" -- you even have to fork over the fee to download the thing. But for OS X 10.4 Tiger there's still the last beta, which should be available for download from Apple.Silva a écrit :Yeah, I've figured that much... Anyway, if there is somekind of emulator I should use, please give me download link. ^___^ I've got MacBook with OS X 10.4 if that's any help...
What BootCamp does is reformat your internal hard disk and set up a partition (analogous to a bureau drawer) onto which you can install a licensed (so Apple hopes) copy of one of the two latest Windows OSes. If the "drawer" is big enough, you can certainly "fit" application programs like PhotoFiltre into it, and when booted into Windows XP, for instance, run it and the rest of the Windows software as if you were on a PC.
Silversleeves
{15 years Mac OS at home, 8 as a power-user, 5 in OS X and 10 months as an Apple support tech}
(Missed passing my AASP for OS 9.2 by 33pts ): )
Sunsparkle
- Version de PhotoFiltre : 9.0.0
- Système d'exploitation : Windows ME
Hi, I have the same dilemma lol I want to use photofiltre studio but have just been given a mac and I'm stuck as I can't afford and emulator and windows, and I'm not sure about downloading as I don't want to mess up the macbook??
~Sunsparkle~
~Sunsparkle~
bruha
I faced this problem too and resolved it with Wine for Mac.
Pretty full instruction how to install it on Mac.
Photofiltre works fine on MacOS Sierra so far.
If you want to put App to the Dock, you can try generated by me simple script, presume that you installed your Photofiltre in default folder C:/Program Files (x86)/
