Is it possible to radiate lines of light?
Sunsparkle
Version de PhotoFiltre : 9.0.0
Système d'exploitation : Windows ME
Message par Sunsparkle »
Hi all,
Me again, hehe. Is it possible with photofiltre studio, or with a plugin of some sort to radiate beams of light from a certain place in an image, or an object, please?
Here is an image example: - http://kss.mysticalaura.com/interactive ... 4_1024.jpg
It would be interesting to know if it is possible to create the lighting effect or something similar to these: -
http://i47.photobucket.com/albums/f159/ ... wall01.jpg
http://i47.photobucket.com/albums/f159/ ... 4b5932.jpg
Thankx,
~Sunsparkle~
Re: Is it possible to radiate lines of light?
It's possible using a mask in the modeul PhotoMasque for example. Just creat or find black and white mask to apply.
You can use special brushes too. A lot of brushes exists in the wb :wink:
