Install new version
Anneriek
Version de PhotoFiltre : 6.3.0
Processeur : celeron 1.60 GHz
Mémoire RAM : 1024 Mb
Install new version
Message par Anneriek »
Hi there,
I am new to Photofiltre, but I like it very much. 8)
I got the tip from my mother (!!) :wink: She was already using Photofiltre. I immediately downloaded and installed it, so I have got version 6.3.0, the latest ! She has still got version 6.2.6. Does she need to de-install the old version en install the new version or... is there a possibility to update from within the program ??
Thanks for helping,
Greetings from the Netherlands.
Anneriek
Re: Install new version
don't remove old version, install directelly
