Hi. I am new to Photofiltre and was having trouble blending images to my signature I was making.
I followed the tut but it didn't work. When I paste the image in the sig, it doesn't blend in with the background.
How would I make the blending image look like it's part of the background and not just look like it was put in.
Blending Images
dad2paisley
- Système d'exploitation : WindowsXP
Re: Blending Images
Hi,
if we know which tut about, it sould be a little more easy to understand.
And for which version of PhotoFiltre ?
dad2paisley
Re: Blending Images
All right, it's more comprehensible.
In step B : the portrait and the gradient must be associated in an unique image (width of portrait is exactly double sized).
In step C : the blend doesn't be pasted by a classical way, but with : Menu Edit >> Paste Special >> Image with linked mask
When done, the paste is not yet complete, do a right clic in the pseudo-selection and you can adjust Opacity in "Paste options".
Until you don't press Enter or validate paste, you can adjust this option.
Don't forget that in a tutorial, you have to consider each word.
dad2paisley
Re: Blending Images
Thank you for your help. I will give that a try.
