About Jpeg Compression
The_General
- Version de PhotoFiltre : 6.3.0
- Processeur : Intel Pentium 4 2,66Ghz
- Mémoire RAM : 256MB
I used the jpeg compression in 100% and the image isn't perfect, why does this happen? I tried with other programs and the image was perfect
Re: About Jpeg Compression
What other programs for example ?
100 is the best quality but the image is compressed too.
The_General
Photoshop for example, the red when i save something turns dark red, with some pixels errors. I don't know about the compression but in photoshop the image usually when you save is smaller.Antonio a écrit :What other programs for example ?
I know photofiltre isn't a photoshop, but it's really light, anyway i guess to improve the jpeg save won't make it heavier
