Combining photos and adjusting them ...
RdR
Message par RdR »
I want to create a photo (for printing) consisting of two photos on black background. While I have no problem assembling this setup, I don't know how to properly adjust the photos on that black background, e.g. by centering them horizontally or finding equal distances from top and bottom. :roll: Any advice on this???
Regards
Roland
After paste, you can use the function Selection > Center for example
RdR
Message par RdR »
Thanks! Yes, that solved one problem and when checking the possibilities under this menu I could solve the second problem as well. :D
Regards
Roland
