Photofiltre 6.0.2 will not load
PeterTheBike
I have just installed Photofiltre 6.0.2 and it will not load.
My PC is running Windows XP Home Edition SP2.
Looking in Task Manager there is a process running for Photofiltre, but no application.
I have tried running in Safe Mode, installing with my anti-virus disabled, but Photofiltre will still not load.
My previous version of Photofiltre worked immediately before I tried to upgrade. I think my previous version was 6.0, but it might have been 6.0.1.
Any suggestions please?
Peter
Peter
donwload the last version 6.1 in the official web site (http://www.photofiltre.com)
PeterTheBike
- Membre d'honneur
PeterTheBike
- Membre d'honneur
Maarten
le logiciel ne démarre pas
Hi,
I have exactly the same problem (version I downloaded on march 6), also with Windows XP SP2.
When I try to start the program, nothing happens. Installation went fine (dutch, english and french zip-version).
I also installed a newer twain_32.dll, but nothing helps. I have switched off my Norton antivirus.
The only thing that changes after I've tried to start the program, is that my computer is becomming extremely slow, so I have to restart my computer.
What's the problem?
Thanks, Maarten.
What's the problem?
Thanks, Maarten.
Maarten
Photofiltre doesn't start
Hi,
No, I didn't find any solution to my problem. Also because Norton antivirus and my firewall are switched off when I try Photofiltre. And I don't have any resident anti-spyware prgrams running.
Maarten.
Maarten.
- Membre d'honneur
PeterTheBike
