Brushes & Nozzles pfs 9,0 need help
Nidirock
Message par Nidirock »
hello there,
please can someone tell me, why if i want to use nozzles in photofiltre studio i only can use the first pic in the line? to use nozzles i have to click at the strawberry, right? i´m sorry but i don´t know how to use all of the nozzles.... :shock:
and how can i create brushes? i tried everything...the size, png format...but i can´t use them :? i tried it in transparent..or in white...nothing...
and all websites for photofiltre are in french and so i don´t understand anything....please help me :(
Nozzles are dynamique brushes, you can not use only one element, all image element are used by sequence.
It's not like advanced paintbrush
Nidirock
:lol: :clap: haha ok...now i´m laughing about myself...ok thanks for your reply :oops:
and whats about the brushes? i would like to create some by my own...but i don´t know how....
anyway..i´m still laughing about the nozzles :lol:
just create png file with correct size (Width = BrushCount * Height) and insert it in the Brushes folder
