New freeware : Photo Black & Color
here si a new freeware to convert image to black and white preserving some parts in color :
http://www.photofiltre-studio.com/tmp/PhotoBC-en.zip
The documantation is in french only for the moment, if somebody can translate this :wink:
http://www.photofiltre-studio.com/doc/photoBC.htm
tannie
Version de PhotoFiltre : Free and Studio 9
Message par tannie »
Awesome,thx Antonio!Yeah please someone translate this! :(
Nobody can translate this doc in english :cry:
Re: New freeware : Photo Black & Color
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
Hello!
I think this is very interest effect. I like in the new PFS.
Mészáros Tamás
Vista UAC problem when I running this the software. Why? :?: :(
I think it's better to install XP because with vista lot of my softwares don't works correctelly :wink: :D
Mészáros Tamás
Ok. But My Windows Vista 64 is legal... :roll: to integrate for PFS? :|
Best Regards Antonio
Ok legal, but for the moment XP works better than vista :wink:
Mészáros Tamás
:cry: I'm dismal...
The problem it is that the bug seems to occur only on your PC. Others Vista users do not seem to have it. In this case, i can not find the problem :cry:
Mészáros Tamás
Antonio a écrit :The problem it is that the bug seems to occur only on your PC. Others Vista users do not seem to have it. In this case, i can not find the problem :cry:
I think that's cause, we to buy low legal Vista Home Basic 64 with Szálka company(webpage help http://www.szalkafa.hu and barter :oops: )...and I think this modern with ×64 AMD CPU...this my job cost... :roll: for me...by company.
Best Regards: :oops:
Luxther Defaul
Message par Luxther Defaul »
Hi Antonio.
My contribution to the Photo Black & Color.
Documentation translated = Portuguese of the Brazil.
http://br-photofiltre.110mb.com/pfs/?id=manualPhotoBC/
Thanks!
obrigado :wink:
Mészáros Tamás
Luxther Defaul a écrit :Hi Antonio.
Thanks!
Super ... congratulation. :clap:
