Compression when saving
spaarks
Version de PhotoFiltre : 7.4.2
Processeur : Turion 64 X2
Mémoire RAM : 1G
Message par spaarks »
Is there any way to save in the same compression ratio as the original jpg file?
My camera output is jpg but there seems to be no way I can tell what the compression ratio is.
Denis
no, the compression value is not saved :cry:
